Remove Branding
Hi
Any pointers on how to remove the branding package?
From reading it should be use netinstall. We have tried that, multiple times.
The device is a ac2, running ros7.8.
NetInstall absolutely remove branding, but if you do not set the -r option on Linux or you leave “Keep old configuration” selected on windows version…
