I have a question,
Is there any posibility to remove connections via script , when the ppoe descconects? I have a problem with Voip when internet via ppoe disconnect,
I have this for remove connections but I don’t know ho to do when ppoe disconnects
Any advice will be apreciated
/ip firewall connection remove [/ ip firewall connection find dst-address~“x.x.x.x:5060”]
Thank you
In “/ppp profile” you have the option to set “on-up” and “on-down” scripts.
Create a separate profile with your desired scripts, use that profile for your outbound PPPoE session.
I have a question,
Thank you
Please do some search instead of open new topic.
Is better to close all invalid connections than only the VoIP
http://forum.mikrotik.com/t/script-to-clean-firewall-connections-after-public-ip-changes/135275/5
you can paste this on on-up script on profile used from pppoe-out1, do not change nothing, it retrieve automatically new pppoe ip (can be the same)
:global newIP [:tostr $"local-address"]
/ip fire conn
:foreach idc in=[find where timeout>60 and (!(reply-dst-address~$newIP))] do={
remove [find where .id=$idc]
