Remove Firewall Connections when default Route changes
i have 2 default routes for 2 WAN Connections.
The first has Dist 1 and the second Dist 5. When Wan connection 1 fails the router switches to connection 2. So far so good.
But all connections to Dist 1 stay open.
So if i do a permanent ping to 1.1.1.1 and connection 1 fails, the ping fails too even though the router switches to connection 2. I have to stop the ping and wait 10 seconds. Then the connection times out in firewall → conncetion. Then i can ping again using connection 2.
Is there a way to remove connections automaticaly when the default route changes?
BR
mode
no one? is this such an unusual question? :frowning:
