Remove host from hotspot using php api
Hello
I am trying to remove host from hotspot using php api
when i am running teh following code in mikrotik terminal its working fine
ip hotspot host remove [find where address="10.1.3.7"]
now i am trying the same with php api its not working here is my code
require('mikrotik_api/routeros_api.class.php');
$API = new routeros_api();
$API->debug = false;
if ($API->connect("$nas_ip", "$nas_username", "$nas_password")) {   // Change this as necessery
$ARRAY = $API->write("/ip/hotspot/host/remove", array("?address" => '10.1.3.7'));
print_r($ARRAY);
   $API->disconnect();
please help me to solve this problem
thank you
in Terminal, you do ‘find’, then ‘remove’. Why do you try ‘remove’ without ‘find’ in API? :slight_smile:
http://forum.mikrotik.com/t/remove-active-user-hotspot-php-api/23834/1
