remove imagine interface bandwitch from graph
hello i stuck on some stupid problem that sometimes smto (or routeros) probe give to big info about transfer for example i get today 2.5gbits on intefrface where bandwitch is max 20mbits i have it set to 17000000 (in properities) but id dont seams to work. any ide how to remove this big points? because i cant see any thing else there :slight_smile:
You would have to edit the database if you are on 4.x, on 3.6 you could add the graph to a chart and then you could go edit the raw values in the chart somewhere…
