Remove interface from console
Hello everybody!
Does anyone know, how to remove dynamic interface from console? “Interface remove” not work. I get interface name with dynamic flag, but cannot remove them from console(from winbox-without problems).
remove all dynamic interfaces:
/interface sstp-server remove [/interface find dynamic]
remove particular interface (in this case connected SSTP client):
/interface sstp-server remove [/interface find name="<sstp-vecernik>"]
As far as I know, you can’t issue command “remove” for all interfaces in ****
/interface
menu, because that menu contains all interfaces, including non-removable (e.g. ethernet/wlan)
Due to that, you need to go to some sub-menu.
Funny thing is, that the sub-menu does not need to be relevant to your interface. (for example I can delete my SSTP interface from PPTP sub-menu)
vecernik87, thank you! It works also with ovpn-server.
