I have an ip firewall filter rule much like this:
1 ;;; accept gre for pptp chain=input action=accept protocol=gre dst-address=192.0.2.12
I want to remove the dst-address constraint at the command line. I can set it to 0.0.0.0/0, which has the same effect, but that seems like a workaround.
Can anyone point me in the right direction?
Thanks, ==ml
You can search using the IP and protocol… but be careful in case any other rules contain the same IP & protocol (they will be unset as well):
/ip firewall filter unset [find dst-address="192.0.2.12" protocol="gre"] dst-address
Or change it by using the item number you get after doing a print (in yours it was the number 1):
/ip firewall filter unset 1 dst-address
