model: MIKROTIK RB2011UiAS-2HnD-IN
I have hired wimax which comes to me through an external antenna, this connects to a poe adapter and this takes out a connection to my microtik router. Could you remove that adapter and connect directly the wimax antenna (where I receive my internet connection) to the microtik router ??? if this is how the configuration would be ?
It depends on the Device you want to Power (aka. wimax-Antenna)
The RB2011UiAS-2HnD-IN only has a Pasive PoE on ether10.
Max out ether10 (input 18-30 V) 510 mA
If the device is compatible, you can connect the device via ether10
and it should be “Plug&Play”
the problem is the configuration in ppp would put the interface 10 instead of the 1 (currently)
I am sorry, I was focused on the “PoE” question…
Of course, you may need to edit the configuration of the Mikrotik-Device.
If you are comfortable with RouterOS, it shoudn’t be a “Problem”
–>> Tipp : Make Backups & use Safe-Mode =)
If you need help or advice
Post the Config of your Router (/export hide-sensitive file=anynameyoulike)
