Remove port mirror
Hi All,
So we are about to run a port mirror for the next 10 days and before I go ahead and set the mirror with:
/interface ethernet switch set mirror-source=ether2 mirror-target=ether4
I’d like to confirm the command to remove the mirror and I don’t have a test router at the moment as it has been deployed for a failed one. Can anyone help with the remove syntax?
Thanks,
Ben
The only way I have found to do it is through the WinBox interface. Once you add the switch through the terminal the option will show up on the left in WinBox.
It may be there before you add it, but I struggled with this for hours because I have the CCR1009-8G-1S and could not find any clear documentation outside of the forums.
Hope that helps.
This is the RouterOS command to disable port mirroring from command line interface:
/interface ethernet switch set switch1 mirror-source=none mirror-target=none
