Remove resolved doesnt work
In Dude v4.02beta button “Remove resolved” doesn´t function. I cant remove solved problems…
For now you can select the settings for a sub map and clear all outages on each submap or on each device. On 4.0 beta 2 the global remove resolved button is under services/outages but it doesn’t work as you noted.
