Remove script action from log
Hello everyone.
Maybe you guys can shine a light on this for me. It isn’t exactly a problem, it’s more of an annoying thing. I have a script that runs every 30 sec on my CCR 1072. It’s just pinging an IP and spitting a enable=yes ou no depending on the result. It works fine, but I get the memory log action every time it runs, and it kind of ruins my log with this useless info. Is there a way to make this single script not to log it’s actions or to make the enable/disable interface action not to appear on the log? I tried reading all the documentation on logging and tried to find anything like this online but had no success.
Thanks again for the help!
