remove the diversity switch
i have alot of cards that is not uesable now its become littel bit deaf (-15 to -20) db of the drop on the signal
i remove the diversity switch and i solder direct wires i good very good RX signal
but there is no TX signal @ all
anyway have this knowelage or he did that before?
You have no TX becouse:
  • you have specified the wrong tx connector on ROS;
  • the card transmit ONLY on one connector, and it is not which you soldering on.
  • the TX section is damaged.
Sorry for my bad english.
do you have any digram will make it easy for me
i dont think the card is damag becouse beforei remove the switch it was working
Uhm…sorry, no diagram.
What i want to say, is that on your card you have TWO line on pcb to the diversity switch, and it’s probable that you solder connector on the wrong line. Try to solder your pigtail/connector on the other line, and try if you have some tx power.
i made it in this time looool
just finish with it and i will sleep now then i will do full test tommoro
thanks mipland for late night help
cheers
taloot,
how did your testing go? Did you make it work? If so could you please post more info. I would like to attempt this too.
Thanks,
Gerard
