removing and adding mangle rule via ssh
HI,
I use below command in order to add mangle rule
ip firewall mangle add chain=prerouting action=mark-routing new-routing-mark=blocking passthrough=yes src-a
ddress=87.54.124.249
working perfect :slight_smile:
The question is how to remove the rule using src-address?
I was trying below command but do not want to work:
ip firewall mangle remove where src-address=87.54.124.249
/ip firewall mangle remove [/ip firewall mangle find src-address=87.54.124.249]
it make sens, executing correctly but not removing from mangle
Sorry, this gets me every time. You have to quote the IP address.
[admin@MikroTik] /ip firewall mangle> print where src-address=1.1.1.1
[admin@MikroTik] /ip firewall mangle> print where src-address="1.1.1.1"
 6   chain=forward action=change-ttl new-ttl=set:1 src-address=1.1.1.1
[admin@MikroTik] /ip firewall mangle> /ip firewall mangle remove [/ip firewall mangle find src-address="1.1.1.1"]
So the below works:
/ip firewall mangle remove [/ip firewall mangle find src-address="87.54.124.249"]
Big thanks, it works very well !!! :smiley:
