Removing cAP AC from wall mount
Hi guys not sure if this is the right forum for this topic.
Anyways I would like to ask if anyone knows how to remove a cAP AC from it’s metal wall mount?
I know there’s a hook underneath but how do we access this once it is firmly in placed on the wall?
https://i.mt.lv/cdn/rb_files/INSTR-CAPG-USER-MANUAL-V1-180202095453.pdf
Thanks for the reply, but the manual only shows how to lock it in place by turning clockwise. I’m trying to turn it counter clockwise but it’s so hard I’m afraid it will break if I force it
You do have to simply turn it. There is no other tab or anything. I hope the drywall anchors do a good job, of course :slight_smile:
Thank you sir, hope and pray the dry wall holds up :laughing:
