I have both an RB433AH and an RB750G.
I have concluded that on the RB433AH, it is not possible to remove Ether2 and Ether3 from Switch 1.
I have concluded that on the RB750G, it is not possible to remove Ether2, Ether3, Ether4 and Ether5 from Switch 1.
Are these appropriate conclusions ?
F.
mrz
August 25, 2010, 5:16am
2
It is possible to remove ports from switch by setting master interface to none.
Flags: X - disabled, R - running, S - slave
NAME MTU MAC-ADDRESS ARP MASTER-PORT SWITCH
0 R ether1 1500 00:0C:42:21:78:40 enabled
1 R ether2 1500 00:0C:42:21:78:41 enabled none switch1
2 R ether3 1500 00:0C:42:21:78:42 enabled none switch1
As you can see, port 0 is associated without a switch
Port 1 and Port 2 have master-port as NONE but are tied to switch1.
F.
mrz
August 25, 2010, 11:22am
4
SWITCH group indicates only that ethernet is controlled by the same switch chip. It doesn’t mean that ports are actually switched together. master-port parameter does the switching configuration.
Does that mean that Port 0 is not on the IC plus switch chip on the 433AH ?
mrz
August 25, 2010, 11:55am
6
Yes, only ether2 ether3 are controlled by switch chip.
