Can you guys at Mikrotik please put in a confirmation box that you have to click when removing users? When resetting the the counters you have to choose, why not whith the removing as well.
Another problem I have is that when I choose a bigger number than 20 users to be displayed on the screen the edit box doesn’t display fully. The reset counters aren’t visible and you have to scroll down to see it and then it dissapears again because your cursor isn’t on the dropdown box anymore.
Keep up the great work!
