Removing VLAN 0 802.1p tags on CRS112?
Is it possible?
My ISP tags things with vlan 0 802.1p tags, and I want to remove them then from ether4 and then pass ether6 through to my router.
There is a thread about this, so far only tp-link switches and some routers like RB4011 can remove it.
I don’t understand why my CRS112 can’t, but it doesn’t work.
Cisco switches apparently also allow removing 802.1p tags.
Anyone have any advice?
I don’t know if it is possible to strip the priority tags on your switch, but am very curious why do you need to do that at all?
If I don’t dhcp client won’t get an ip address even though dot1x client shows authenticated.
AT&T does this intentionally to try to force us all to use their shitty gateway units that lack a real bridge mode.
Here’s an example:
While I failed to get my CRS112 to strip vlan headers, surprisingly the CSS326 was able to do so without much effort.
