I need to change ip address of many router can I do this with script ? for example 172.16.57.2/24 but only .57. will change with .58. at ip>>address and at routing>> Ospf >>Network.
if possible I will add script to all boards and do schedule to make all board same time.
It is tricky. I would do “/ export file=config-…” for all of them, or at least the main types, and get the files via scp or ftp.
Then you can look at the places that need renumbering. I don’t use ospf, but I’d still need to change things in a lot of submenus:
/ip pool, /ppp profile, /ip address, /ip dhcp-server-network, /ip dns static, lots of places under /ip firewall, and /ip route
Probably if you do:
generate a backup export of all configurations, inspect them with grep…, prepare the script, test with one test router for errors
deploy the script in all routers via scp/ftp, schedule it to run at a fixed time
probably reboot all routers once it is done, or you will have to flush connections, dhcp-client/server leases, ospf state…
check which ones are not coming back and fix them
for the ones apparently running, repeat the export of all configuration and look again for the prefix for missing cases
You can do it with a reasonable downtime, depending on the number and location of routers.
