Repair LHG 4G KIT (No power)
I have a Mikrotik LHG 4G Kit that won’t power on. It seems to have been damaged by a storm and now it doesn’t turn on. I opened it up to inspect the damage and noticed that the transistor marked as Q3 is damaged, but I can’t clearly see its code.
I am writing to see if anyone can provide a photo of this part of the board, showing it clearly. I have searched online but haven’t found any with sufficient resolution or clarity to identify it. I would also appreciate it if anyone knows the reference type. I believe it is 2PH (PNP transistor KST5086) but I’m not sure, or if you have a repair manual, as I have found ones for other products, but not for this one. Thank you very much.
Best regards.
