Repeated gateway unreachable issues
I am having issues with a IPsec VPN. Normally the tunnel works but occasionally even after reboots I get unreachable gateway for the static route. I have my config below. I am able to ping the gateway that says unreachable though from the router and from a computer behind the router. That IP is only available through the IPsec tunnel so I know that part is working. However, any IP that is supposed to be reachable after that I cannot reach.
[code]# may/08/2020 14:22:35 by RouterOS 6.44.5
# software id = K09T-BU80
# model = RB4011iGS+
# serial number = B8F30A776057
add admin-mac=74:4D:28:A3:D3:AD ageing-time=5m arp=enabled arp-timeout=auto auto-mac=no dhcp-snooping=no disabled=no ether-type=0x8100 fast-forward=yes frame-types=admit-all igmp-snooping=no ingress-filtering=no mtu=auto name=bridge protocol-mode=none pvid=1 \
    vlan-filtering=yes
add ageing-time=5m arp=enabled arp-timeout=auto auto-mac=yes dhcp-snooping=no disabled=no fast-forward=yes igmp-snooping=no mtu=auto name=bridge-nat protocol-mode=none vlan-filtering=no
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:AC mtu=1500 name="01 - " orig-mac-address=74:4D:28:A3:D3:AC rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether2 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:AD mtu=1500 name=02 orig-mac-address=74:4D:28:A3:D3:AD rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether3 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:AE mtu=1500 name="03 - Internal Switch (POE)" orig-mac-address=74:4D:28:A3:D3:AE rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:AF mtu=1500 name=04 orig-mac-address=74:4D:28:A3:D3:AF rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether5 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:B0 mtu=1500 name=05 orig-mac-address=74:4D:28:A3:D3:B0 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:B1 mtu=1500 name=06 orig-mac-address=74:4D:28:A3:D3:B1 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:B2 mtu=1500 name=07 orig-mac-address=74:4D:28:A3:D3:B2 rx-flow-control=off speed=100Mbps tx-flow-control=off
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:B3 mtu=1500 name="08 - Internal Switch" orig-mac-address=74:4D:28:A3:D3:B3 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:B4 mtu=1500 name=09 orig-mac-address=74:4D:28:A3:D3:B4 rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no full-duplex=yes l2mtu=1592 loop-protect=default \
    loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=74:4D:28:A3:D3:B5 mtu=1500 name="10 - Uplink" orig-mac-address=74:4D:28:A3:D3:B5 poe-out=off poe-priority=10 power-cycle-interval=none !power-cycle-ping-address power-cycle-ping-enabled=no \
    !power-cycle-ping-timeout rx-flow-control=off speed=1Gbps tx-flow-control=off
set [ find default-name=sfp-sfpplus1 ] advertise="" arp=enabled arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited disabled=yes full-duplex=yes l2mtu=1600 loop-protect=default loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
    74:4D:28:A3:D3:B6 mtu=1500 name=sfp-sfpplus1 orig-mac-address=74:4D:28:A3:D3:B6 rx-flow-control=off speed=10Gbps tx-flow-control=off
/queue interface
set bridge queue=no-queue
set bridge-nat queue=no-queue
/interface ethernet switch
set 0 !cpu-flow-control mirror-source=none mirror-target=none name=switch1
set 1 !cpu-flow-control mirror-source=none mirror-target=none name=switch2
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
set [ find name=all ] comment="contains all interfaces" exclude="" include="" name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" include="" name=dynamic
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet default-route-distance=2 name=default use-peer-dns=yes
set [ find default=yes ] authentication-types="" disable-pmkid=no eap-methods=passthrough group-ciphers=aes-ccm group-key-update=5m interim-update=0s management-protection=disabled mode=none mschapv2-username="" name=default radius-called-format=mac:ssid \
    radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none \
    static-sta-private-algo=none static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=default !parent-queue !queue-type shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec mode-config
set [ find default=yes ] name=request-only responder=no
/ip ipsec policy group
set [ find default=yes ] name=default
add name=group1
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-256,aes-128,3des hash-algorithm=sha1 lifetime=1d name=SFOFFICE nat-traversal=yes proposal-check=obey
add dh-group=ecp384,ecp521,ec2n185,ec2n155,modp8192,modp6144,modp4096,modp3072,modp2048,modp1536,modp1024,modp768 dpd-interval=2m dpd-maximum-failures=5 enc-algorithm=aes-256,camellia-256,aes-192,camellia-192,aes-128,camellia-128,3des,blowfish hash-algorithm=md5 \
    lifetime=8h name=200PAUL nat-traversal=no proposal-check=obey
/ip ipsec peer
add address=10.10.41.4/32 disabled=no exchange-mode=main name=SFMBOffice profile=SFOFFICE send-initial-contact=yes
add address=10.10.40.18/32 disabled=no exchange-mode=main name=SF-200PaulAve profile=200PAUL send-initial-contact=yes
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1,md5 disabled=no enc-algorithms=aes-256-cbc,aes-256-gcm lifetime=30m name=default pfs-group=modp1024
add auth-algorithms=sha512,sha256,sha1,md5 disabled=no enc-algorithms=aes-256-cbc,aes-256-ctr,aes-256-gcm,camellia-256,aes-192-cbc,aes-192-ctr,aes-192-gcm,camellia-192,aes-128-cbc,aes-128-ctr,aes-128-gcm,camellia-128,3des,blowfish,twofish,des lifetime=10h name=\
    200Paul_Policy pfs-group=modp1024
add name=dhcp ranges=10.2.87.99-10.2.87.254
add address-pool=dhcp authoritative=yes bootp-support=static disabled=no interface=bridge-nat lease-script="" lease-time=10m name=dhcp-server use-radius=no
/port
set 0 baud-rate=115200 data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
set 1 baud-rate=115200 data-bits=8 flow-control=none name=serial1 parity=none stop-bits=1
/ppp profile
set *0 address-list="" !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list !local-address name=default on-down="" on-up="" only-one=default !outgoing-filter \
    !parent-queue !queue-type !rate-limit !remote-address remote-ipv6-prefix-pool=none !session-timeout use-compression=default use-encryption=default use-ipv6=yes use-mpls=default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-horizon !bridge-path-cost !bridge-port-priority change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter !insert-queue-before !interface-list !local-address name=default-encryption on-down="" on-up="" only-one=default \
    !outgoing-filter !parent-queue !queue-type !rate-limit !remote-address remote-ipv6-prefix-pool=none !session-timeout use-compression=default use-encryption=yes use-ipv6=yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=\
    2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
    pcq-total-limit=2000KiB
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set "01 - " queue=only-hardware-queue
set "02" queue=only-hardware-queue
set "03 - Internal Switch (POE)" queue=only-hardware-queue
set "04" queue=only-hardware-queue
set "05" queue=only-hardware-queue
set "06" queue=only-hardware-queue
set "07" queue=only-hardware-queue
set "08 - Internal Switch" queue=only-hardware-queue
set "09" queue=only-hardware-queue
set "10 - Uplink" queue=only-hardware-queue
set sfp-sfpplus1 queue=only-hardware-queue
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id !confederation disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no redistribute-static=no router-id=\
    0.0.0.0 routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 !mpls-te-area !mpls-te-router-id name=default out-filter=\
    ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=backbone type=default
/routing ospf-v3 instance
set [ find default=yes ] disabled=no distribute-default=never metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 name=default redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
/routing ospf-v3 area
/snmp community
set [ find default=yes ] addresses=10.0.0.0/8 authentication-protocol=MD5 encryption-protocol=DES name=wificacti read-access=yes security=none write-access=no
add addresses=10.8.254.0/24 authentication-protocol=SHA1 encryption-protocol=AES name=MonkeyV3 read-access=yes security=private write-access=yes
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000 disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=yes name=remote remote=10.8.254.76 remote-port=514 src-address=0.0.0.0 syslog-facility=local5 syslog-severity=auto syslog-time-format=bsd-syslog target=remote
/user group
set read name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!write,!policy,!dude skin=default
set write name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,api,romon,tikapp,!ftp,!policy,!dude skin=default
set full name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp skin=default
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man manager
set ca-certificate=none certificate=none enabled=no package-path="" require-peer-certificate=no upgrade-policy=none
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=no interface=all
/certificate settings
set crl-download=yes crl-store=system crl-use=yes
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=02 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
    point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface="03 - Internal Switch (POE)" internal-path-cost=10 learn=auto multicast-router=\
    temporary-query path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes unknown-unicast-flood=yes
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=04 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=05 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=06 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=07 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface="08 - Internal Switch" internal-path-cost=10 learn=auto multicast-router=\
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=09 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface="10 - Uplink" internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=\
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes ingress-filtering=no interface=sfp-sfpplus1 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge-nat broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=no ingress-filtering=no interface="01 - " internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m udp-stream-timeout=3m udp-timeout=10s
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=yes send-redirects=yes tcp-syncookies=no
/ipv6 settings
set accept-redirects=yes-if-forwarding-disabled accept-router-advertisements=yes-if-forwarding-disabled forward=yes max-neighbor-entries=512
/interface bridge vlan
add bridge=bridge disabled=no tagged="sfp-sfpplus1,10 - Uplink,bridge" untagged="" vlan-ids=2001
/interface detect-internet
set detect-interface-list=none internet-interface-list=none lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled one-session-per-host=no use-ipsec=no
add comment=defconf disabled=no interface=bridge list=LAN
add comment=defconf disabled=no interface="01 - " list=WAN
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:B3:14:72:A5:42 max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" caps-man-names="" certificate=none discovery-interfaces="" enabled=no interfaces="" lock-to-caps-man=no static-virtual=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=10.2.87.1/24 disabled=no interface=bridge-nat network=10.2.87.0
add address=10.10.41.203/26 disabled=yes interface=bridge network=10.10.41.192
add address=10.7.80.41/16 disabled=yes interface=bridge network=10.7.0.0
add address=10.10.1.107/29 disabled=no interface=bridge network=10.10.1.104
/ip cloud
set ddns-enabled=no ddns-update-interval=none update-time=no
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set store-leases-disk=5m
add address=10.2.87.0/24 caps-manager="" dhcp-option="" dns-server=8.8.8.8,4.2.2.2 domain=monkeybrains.net gateway=10.2.87.1 ntp-server="" wins-server=""
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB max-concurrent-queries=100 max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s servers=10.7.0.1
/ip dns static
add address=192.168.88.1 disabled=no name=router.lan regexp="" ttl=1d
add action=accept chain=srcnat !connection-bytes !connection-limit !connection-mark !connection-rate !connection-type !content disabled=no !dscp dst-address=10.2.86.0/24 !dst-address-list !dst-address-type !dst-limit !fragment !hotspot !icmp-options !in-bridge-port \
    !in-bridge-port-list !in-interface !in-interface-list !ingress-priority !ipsec-policy !ipv4-options !layer7-protocol !limit log=no log-prefix="" !nth !out-bridge-port !out-bridge-port-list !out-interface !out-interface-list !packet-mark !packet-size \
    !per-connection-classifier !priority !protocol !psd !random !routing-mark !routing-table src-address=10.2.87.0/24 !src-address-list !src-address-type !src-mac-address !time !tls-host !to-addresses !to-ports !ttl
add action=accept chain=srcnat !connection-bytes !connection-limit !connection-mark !connection-rate !connection-type !content disabled=no !dscp dst-address=10.99.99.101 !dst-address-list !dst-address-type !dst-limit !fragment !hotspot !icmp-options !in-bridge-port \
add action=accept chain=srcnat !connection-bytes !connection-limit !connection-mark !connection-rate !connection-type !content disabled=no !dscp dst-address=10.7.0.0/16 !dst-address-list !dst-address-type !dst-limit !fragment !hotspot !icmp-options !in-bridge-port \
add action=masquerade chain=srcnat disabled=no out-interface=bridge !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" disabled=no name=default-trial
/ip ipsec identity
add auth-method=pre-shared-key disabled=no generate-policy=no peer=SF-200PaulAve
add auth-method=pre-shared-key disabled=no generate-policy=no peer=SFMBOffice
/ip ipsec policy
set 0 comment="default, do not remove" disabled=no dst-address=::/0 group=default proposal=default protocol=all src-address=::/0 template=yes
add action=encrypt comment=200PaulAve disabled=no dst-address=10.99.99.101/32 dst-port=any ipsec-protocols=esp level=require proposal=200Paul_Policy protocol=all sa-dst-address=10.10.40.18 sa-src-address=10.10.1.107 src-address=10.2.87.0/24 src-port=any tunnel=yes
add action=encrypt comment="286 12th St" disabled=yes dst-address=10.2.86.0/24 dst-port=any ipsec-protocols=esp level=require proposal=default protocol=all sa-dst-address=10.10.41.4 sa-src-address=10.10.1.107 src-address=10.2.87.0/24 src-port=any tunnel=yes
add action=encrypt comment=200PaulAve disabled=no dst-address=10.7.0.0/16 dst-port=any ipsec-protocols=esp level=require proposal=200Paul_Policy protocol=all sa-dst-address=10.10.40.18 sa-src-address=10.10.1.107 src-address=10.2.87.0/24 src-port=any tunnel=yes
/ip ipsec settings
set xauth-use-radius=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no max-cache-object-size=2048KiB max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no src-address=::
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref !bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=2 dst-address=0.0.0.0/0 gateway=10.10.1.105 !route-tag !routing-mark scope=30 target-scope=10
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref !bgp-med !bgp-origin !bgp-prepend !check-gateway disabled=no distance=1 dst-address=10.7.0.0/16 gateway=10.99.99.101 !route-tag !routing-mark scope=30 target-scope=30
/ip service
set telnet address="" disabled=yes port=23
set ftp address="" disabled=yes port=21
set www address="" disabled=yes port=80
set ssh address=10.0.0.0/8,10.10.40.0/24 disabled=no port=22
set www-ssl address=10.10.40.0/24,10.0.0.0/8 certificate=my-rtr disabled=no port=443
set api address="" disabled=yes port=8728
set winbox address="" disabled=yes port=8291
set api-ssl address="" certificate=none disabled=yes port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set allow-none-crypto=no always-allow-password-login=no forwarding-enabled=no host-key-size=2048 strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=256k enabled=no inactive-flow-timeout=15s interfaces=all
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes ipv6-flow-label=yes is-multicast=yes last-forwarded=\
    yes nat-dst-address=yes nat-dst-port=yes nat-src-address=yes nat-src-port=yes out-interface=yes packets=yes protocol=yes src-address=yes src-address-mask=yes src-mac-address=yes src-port=yes tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes \
    ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/ipv6 address
add address=::10:7:87:1/64 advertise=yes disabled=yes eui-64=no from-pool=MB-Oakland-Office interface=bridge-nat no-dad=no
/ipv6 dhcp-client
add add-default-route=yes default-route-distance=1 dhcp-options="" disabled=yes interface=bridge pool-name=MB-Oakland-Office pool-prefix-length=64 prefix-hint=::/0 request=address,prefix use-peer-dns=yes
/ipv6 firewall filter
add chain=forward comment="Allow Established" connection-state=established
add chain=forward comment="Allow Related" connection-state=related
add chain=forward comment="Allow ICMPv6" protocol=icmpv6
add action=drop chain=forward comment="Drop the rest (inbound)"
add chain=forward comment="Allow outbound" out-interface=bridge
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=yes disabled=no hop-limit=unspecified interface=bridge-nat managed-address-configuration=no mtu=unspecified other-configuration=no ra-delay=3s ra-interval=3m20s-10m ra-lifetime=30m reachable-time=\
    unspecified retransmit-interval=unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/ipv6 route
add !bgp-as-path !bgp-atomic-aggregate !bgp-communities !bgp-local-pref !bgp-med !bgp-origin !bgp-prepend check-gateway=ping disabled=no distance=1 dst-address=::/0 gateway=2607:f598:b740:315::1 !route-tag scope=30 target-scope=10
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s
/routing ripng
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no timeout-timer=3m update-timer=30s
/snmp
set contact="Anders Finn" enabled=yes engine-id="" location="1611 17th St, Oakland" src-address=:: trap-community=wificacti trap-generators=temp-exception trap-target="" trap-version=2
/system clock
set time-zone-autodetect=no time-zone-name=America/Los_Angeles
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system console
set [ find port=serial0 ] channel=0 disabled=no port=serial0 term=vt102
/system identity
set name="MB Office Router - No Clients"
/system leds
set 0 disabled=no interface=sfp-sfpplus1 leds=sfp-sfpplus-led type=interface-activity
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
add action=remote disabled=no prefix="" topics=!snmp,!debug
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes primary-ntp=10.7.0.1 secondary-ntp=0.0.0.0 server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set 5 cpu=auto
set 6 cpu=auto
/system resource irq rps
set "01 - " disabled=yes
set "02" disabled=yes
set "03 - Internal Switch (POE)" disabled=yes
set "04" disabled=yes
set "05" disabled=yes
set "06" disabled=yes
set "07" disabled=yes
set "08 - Internal Switch" disabled=yes
set "09" disabled=yes
set "10 - Uplink" disabled=yes
set sfp-sfpplus1 disabled=no
/system routerboard settings
set auto-upgrade=no baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet boot-protocol=bootp enable-jumper-reset=yes enter-setup-on=any-key protected-routerboot=disabled reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m ping-timeout=1m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=no max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
/tool sms
set allowed-number="" auto-erase=no channel=0 port=none receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=rx filter-interface="03 - Internal Switch (POE)" filter-ip-address=0.0.0.0/0 filter-ip-protocol="" filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" filter-operator-between-entries=\
    and filter-port="" filter-stream=no memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=no stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s use-radius=no
[/code]
