Hi all
trying to get the following repeater configuration to work but I am obviously missing something.
All ip addresses are bridge addresses.
10.0.0.210 as wds station (btw this is main station connected to adsl modem) set with dynamic wds
10.0.0.203 as AP Bridge set with dynaminc wds
10.0.0.204 as wds station with dynamic wds
My routes for 10.0.0.203 are:
0.0.0.0/24 - gateway 10.0.0.10 - interface Bridge
10.0.0.0/24 - Pref source 10.0.0.203 - interface Bridge
My routes for 10.0.0.204 are:
10.0.0.0/24 - Pref source 10.0.0.204 - interface Bridge
My routes for 10.0.0.210 are:
10.0.0.0/24 - Pref source 10.0.0.210 - interface Bridge
I can get all 3 connected but i cannot ping 10.0.0.204 from 10.0.0.210 but i can ping it from 10.0.203 and internet is no longer accessible from 10.0.0.203.
I am aware this is a strange config as my internet is on a station and not the bridge, but it is the only way I can get it done due to geographical layout but I am sure it should work.
I am sure I am setting setting somethin wrong in the routes or as gateway on 10.0.0.203. what should it be? I usually set the gateway for all my AP’s to 10.0.0.10 which is my adsl modem.
Also I get dynamic WDS links appear on 10.0.0.203 for both wds stations but i get no dynamic wds links appear at the stations end. Is this correct?
If I set them manually they appear as disconnected under the bridge and no data shows as passing thru it.
Also I assume Nstrean cannot be used to link the 3 points as 2 get connected and the 3rd keeps connecting and dropping every couple of seconds.
I looked at the wiki exhample but I think there must be something wrong there. It shows all 3 points set as AP Bridge ??? is this right?
and also the gateway is the repeater where I need the gateway to be 10.0.0.210 (my main station)
I know its something small I am missing but I cant get my head round it.
David
