Repeater
Hi everyone! Please help, I have set a qrt device as a wisp ap -bridge mode. However I can’t setup a repeater ( tp-link ) settings are saved successful, I see the device connected even have access on it but I can’t connect thru it. Please help and be patient on me as I am a newbie on mikrotik devices.
But it seems you need to help with tp link…
I tried with asus repeater and edimax as well, same result😣
Does the qrt work well as ap generally? If yes, then other repeater should be transparent…
Yes, qrt is the main ap. I can provide a vpn access. I see those tplink, connected with own adress , fully controllable and working.
Then I don’t understand why they can’t work. Just the misconfiguration could be the problem. Have you tried any mikrotik device in that role?
Just i case can you do MT to MT?
Does tp-link have repeater mode?
As i understand you want TP-Link to repeat signal from MT,right?
Yes they have repeater mode. And I didn’t tried out mt mt. Tplink are mounted in a rooftop of a buildings. The setup worked well until last OS came.
But where the problem lies? What exactly does not work?
I didn’t tried because repeater are mounted on a rooftop so the access is very difficult.
The problem is that I cannot connect after repeater
if you want to make TP-Link repeater, maybe you have got wrong forum
Nichky you got the worong ideea. Thank you
Shall I try something with wss bridge, witch is disabled by the way…?
So you need to solve the repeater. Not the ap. Most probably you set something wrong in the repeater or there is physical connection problem.
jarda, long story short: I can’t repeat the signal with anything. From 2015 it worked like a charm until last os came ( 6.41). Not working neither wth downgrade to version 6.37 like it used to work. Guaranteed link between them is 60 db 58, and 65. I can access repeaters, fully controllable and working.
So you did nothing to repeaters. The ap works correctly, repeaters are connected to it, but your clients cannot connect to repeaters while to ap they can? Is that right? Or they can but are without Internet access? If so, check ttl of the incoming packets. Can the clients reach the rest of network?
No, they can’t connect at all. The only chance is to put ip adress manually and so internet is not working and even so you can’t see the rest of the network
Being connected and having an ip address are two independent things.
I am probably not smart enough to guess what the problem is. Is your dhcp server correctly set to the bridge? Is the bridge configured right?
I can provide you a vpn connection after consultant finishes his work. Even him doesn’t know that the problem it would be… :open_mouth: :frowning:
