Been doing reading into this subject and have tried the following, as suggested in the wiki and other posts in the forums.
- Flashfig utility does apply the config script selected, however when “/system default-configuration print” is called the original config (ether1 192.168.88.1 etc.) still shows.
- Using netinstall reformats, partitions and installs the new ROS (routeros-mipsbe-4.11.npk) image and applies the config script selected, however the default config is still the original (ether1 192.168.88.1 etc.).
Question:
What would be required to replace the factory shipped default config with a script of my own? When “/system reset-configuration” is executed I want my new custom script to be executed.
Many thanks for your assistance.
