hello, i have a link nstreme-dual with 2 r52 cards at 800m .its up for more than a year with thrughput 50-60 mbit fdx stable in 40mhz chanel, i want to know if anybody has a similar link but with n cards with single chain ,i want to reach near 100mb fdx is it posibile with nv2 ? extra info :signal strength -48 -50 , jirouse antenna 24dbi extreme with 50dbm separation noise -100, signal has been exelent all time.
i am loking to buy or not same hardware again, becouse this antennas are not cheap,
yes but this link is in production and i dont want to make test with it, i need other links and i am thinking to order again jirous antenna whic cost 450 euro here for a pair and i dont want to spend money if i cant reach results i dont know if anyone has had any issue r52n with nstreme-dual option, i am using 4 cards for link.
2x rb433+R52n 500mtr distance with lots of interference of plenty other 5Ghz AP’s in short range. (Noise level doesn’t tell you a lot..) 130Mb Tx/Rx rate solid and 100% CCQ stable, 60-70mb aggregated throughput. (Not optimized. Network is optimized for shortest latency, not highest throughput. One trades a bit for the other…)
