Did you enable long-cable mode on the 750UP? That seems to come up as the solution to a lot of users’ 750UP questions when the 750UP is powered via PoE anyway.
/int ethernet poe settings set ether1-poe-in-long-cable=yes
Thanks, but yes. The specs simply can not power 5 POE devices, it does not have enough WATT output to do so. Its a real gimmick. Try connecting 4 sxt’s up to it, they will brown out and reboot in cycles, and thats with just 10ft of cable between them.
But it does not. Have replicated this with many devices and multiple PowerBOXs.
As the powerbox starts to power port 1, then port 2, etc, as it reaches port 4, port 1 will brown out, then port 5 will power and another random port will brown out, and then this creates a constant cycle. Then any heavy load on the radio of one of the devices will cause a heavy draw in watts, and it will brown out. Simple math of the specs shows that it can not power 4 sxts.
You can state all you would like about the devices I have in stock, but they simply can not be relied upon, they do not function well.
Well, as long as the new device is just acting as a switch, it wouldn’t have any impact on your OSPF.
(assuming it doesn’t cause packet loss or drop multicast frames or anything unusual)
A) Use a MikroTik with enough ports to do the routing you want + a mid-span PoE injector. The mid-span can be individual single-port injectors or multi-port. Optionally, the mid-span can be manageable.
A1) Use multiple MikroTik 750UP type devices and don’t put more watts on any individual 750UP than you feel can be supported on a 750UP. Leave one or more ports empty.
B) Ubiquity has some multi-port routers which have PoE out ports. You won’t have RouterOS.
I see how that could be seen that way. However, I am looking to see if anyone has found a piece of hardware (mikrotik or not) that they use to run POE and routerOS. I don’t think that is so much a feature request.
I’m powering networks with 750UP, up to 7 switches and NB400+NS2M with original power adapter but I always use the power jack, just split the wires and add a jack.
in 2-3 weeks is the MUM Europe
for sure, will be announced some new products
i hope a bigger poe switch, and I expect at least one gigabit “unifi ac” cAP
