Replacement Antenna for Groove A 52 ac ?
I’ve been using the Groove A 52 ac on my boat with limited success for a few years now, the plastic antenna is not very robust, in fact it bent over this morning.
Can you guys recommend me a replacement antenna or perhaps even better more robust outdoor wireless router?
Thanks!
How about the poynting antennas ?
I can’t argue against the Poynting antennas but they are pricey. This dual band antenna from Data-alliance is reasonably priced and more robust the antenna included with a GrooveA’s. It is made by Alfa.
w32pamela,
Thanks for recommendations. At those prices I can order a couple of spares from Data Alliance.
Thanks!
