Replacing Century Link Router
Working on an install where they have Century Link as the ISP and TV provider.
There is one cat-5 coming from the ONT to the Century Link router. The cable boxes are connected to the router via cat-5.
I did manage to put the cable boxes into a switch… found there to be no VLAN tags, despite what I was told.
After reading a few articles… it seems that the feed from the ONT will provide a Public DHCP address to a client tagging 201.
Added a VLAN of 201 to an interface… sure enough… I get the Public IP. Internet works… but TV stops after about 7 seconds.
set [ find default-name=ether5 ] comment=\
    "VLAN Tag of 201 applied to this interface" name=ether5-test-WAN
 /interface vlan
add interface=ether5-test-WAN name=4IOT vlan-id=201
/ip dhcp-client
add comment="Tagged WAN" dhcp-options=clientid,clientid,hostname disabled=no \
    interface=4IOT use-peer-dns=no use-peer-ntp=no
add action=masquerade chain=srcnat comment="Masq RLC Net Only" out-interface=\
    4IOT src-address-list=RLCNet to-addresses=0.0.0.0
Now where I am stuck is the TV part.
I found this article..
http://www.dslreports.com/forum/r30270839-Prism-TV-HOWTO-Use-pfSense-with-CenturyLink-FTTH-and-Prism-TV-in-Seattle
I just can’t seam to figure it out.
I am not real familiar with IGMP settings.
Anyone have any insight?
I would suggest to start by installing the multicast package if you have not already done so from the “all packages group” for your particular RouterOS version.
http://www.mikrotik.com/download
Next you can visit the following support page to assist you in configuring the IGMP proxy on your Mikrotik Router.
http://wiki.mikrotik.com/wiki/Manual:Routing/IGMP-Proxy
See if this can help you…
