Reply-Only ARP doesn't work
Has anybody been succesful with reply-only arp feature?
I can’t get it work. In mikrotik documentation they say
“If arp property is set to reply-only on the interface, then router only replies to ARP requests”
It actually doesn’t reply.
My client can’t communicate with Mikrotik when reply-only is set unless I change client arp table manually (add mikrotik arp). That’s not supposed to work that way or maybe I miss something here.
Piotr
P.S. My interface is VLAN if that’s any difference.
What version? Have you tried the latest 2.9 version?
Version 2.8.24 and I haven’t tested 2.9
Piotr
You should upgrade to the 2.8.28 or try 2.9rc latest version.
If the problem exists anyway, than contact support with support output file.
