reply-only still fails
I have a problem with reply-only option. On some interfaces it works for a while and then stops working. I need to disable and enable static arp or renew dhcp lease to make it work again but after a while problem occurse again. Other interfaces works OK. Any ideas?
OS is 2.9.8 , interfaces are eoip.
Piotr
