I made not very nice “solution” and created for every account one pool.
The name of the pool is comming over radius.
The pools are distributed over network by PHP script which is communicating via SSH.
The most worse problem is with function DHCP-PD which is giving prefixes with 3 days timeout.
If the CPE disconnect for short time ( eg. because radio disconnect) the static IPv6 route disappears.
I cannot adjust default lease time (3 days) to shorter .
We really need to set this field via RADIUS manually.
We can’t assign the name via RADIUS.
We need to assign the specific /64 prefix via RADIUS.
Otherwise we have to log onto each router, add a pool with a specific name, and then add the RADIUS group against the customer.
This is an extra step which could be fixed if the RADIUS attribute could accept an actual IPv6 prefix.
+1
We need to assign the specific /64 (for one host) or /56 (router+network behind router) prefix via RADIUS.
and IPV6 Radius accounting information.
Without this feature we a not start testing IPV6 on our ISP network.
or look into installing accel-ppp + BIRD on Linux, Delegated-IPv6-Prefix has been supported for some time now, in the latest git sources (not stable release yet) it just got RFC4638 support as well, and it’s all free software / open source. Yes, it needs more work to set up - that’s the main reason I haven’t switched yet.
when this (Delegated-IPv6-Prefix) feature should be available and also we need Mikrotik-IPv6-Address-List is able to be parsed from radius to RouterOS.
accel-ppp 1.11.0 is released, my PPPoE servers are aging RB1100AH’s and I was hoping to replace them with nice new CCR’s but now considering setting up good old Debian boxes with accel-ppp + BIRD (to redistribute PPPoE clients IPs by OSPF).
Ubiquity Edge-Router (EdgeOS) are Debian / Vyatta based. You can ‘apt-get install $missing-packets’. Perhaps this is an option for someone. EdgeOS is really Free Open Source Software in oposite to RouterOS.
Any news about implementation radius attribute "Delegated-IPv6-Prefix " https://tools.ietf.org/html/rfc4818 ? It is very important! Because without it you can not assign a static ipv6 using billing.
Looks like IPv4 space is going for about 13$ USD an IP at IPv4 auctions etc. Current plan is to give all users a IPv6 /64 and lower speed tier users a NATTED IPv4 rather then a public IPv4. “Delegated-IPv6-Prefix” attribute would sure be helpful.
