[Req] No-Ip Script
i was searching the forums and the wiki trying to find a script to link my mikrotik router with no-ip as i want to access it from outside home , i found some scripts but some aren’t for no-ip and some for no-ip but they were beta or for other versions .. i’m sorry for the request but i really couldn’t find the correct script
i’m using version 2.9.7 if any one could post the script i would be very thankful :slight_smile:
use newer version. There are no reasons why you should use version that old.
