(REQ)Setting Mikrotik Bandwidth Limiter per each IP address
hiii guy’s…my name is XXX from Indonesia-Jakarta
I was join in this forum Mikrotik
I used Mikrotik version 2.8.6 with 6 level key
In this case, i got a problem to set bandwidth limiting from one ip address.
Sample:
Public : 202.12.232.311
Local : 192.168.0.1
i want to limit, 192.168.0.2 until 192.168.0.20
with each ip limit/maxlimit: 20kbps/512kbps arrange like :
192.168.0.2 bandwith 32 kbps/512kbps
192.168.07 bandwidth 64kbps/512kbps
192.168.0.10 bandwidth 128kbps/512kbps
please give me the way..to do it.
and once again how bout setting MRTG from my server Mikrotik. If i have to download script, please give me the links and how to put it in my server.
Thanks before, i hope we can make friendship more…
queue simple> add name=queue 1 interface=Local target-address=192.168.0.2/32 max-limit=32768/524288
queue simple> add name=queue 2 interface=Local target-address=192.168.0.7/32 max-limit=65536/524288
queue simple> add name=queue 3 interface=Local target-address=192.168.0.10/32 max-limit=131072/524288
and for MRTG you can use MT 2.9.1 or 2.9.2
bro, if i used ip address client like :
192.168.0.2
subnet : 255.255.255.0
gateway : 192.168.0.1
DNS : 192.168.0.1
mmhh the scripts it’s dosn’t work.
i’try to input
queue simple> add name=Master interface=Local target-address=192.168.0.2/24 max-limit=131072/524288
it’s fail. mmmhh please let me know if:
192.168.0.2/32 what’s for the subnet?
192.168.0.2/29?
Thanks before man.
netmask muse be 32 or 255.255.255.255 it refer to one IP address if you use netmask 24 all range of 192.168.100.0 be queue
Thanks Bro…i solve my problem.
Now i have a new one proble.
i have problem with my proxy.
How could to input my transparant proxy, so i if i didn’t insert ip proxy in internet explorer. I wanna client can same like me if the web i protect, they can’t access that pages. please give me the solve
Just Like this picture
I just want to, give solution if the address is invalid so the http error will make interface my email address as administrator. I used OS MT versi 2.8.6 with 6 level key.
Please give me the rule to input the scripts…
Thanks before…bro.
ip web-proxy>add url=“www.xxx.com” action=deny
