req: show wireless registration table
it would be great if you could show wireless registration table for interfaces, or subnets
You already have that in SNMP Tab in Settings!
Cheers…
I know, but it would be nice if you could show signal streng in lines, beside rx and tx value…
(you dont have option to insert that as a variable)
:confused:
I have beta 16 and I see signal strengths.
how? what variable do you insert?
this is how my label looks like:
Rx: [Interface.InBitRate]
Tx: [Interface.OutBitRate]
I tried inserting [Interface.MediaOid] but dont know how to set what mediaoid shold be shown
At the moment it is not possible to view custom SNMP values on network maps link labels. Only values from interface table.
When I go to Settings , SNMP then I select wireless registration table I can see my clients signal strength and all wireless interfaces signal strengths.
