reqiured @0 mbps link suggest card and borad ....
Kindly suggest wanted to use Router board 532 with Senao Nmp-8602 card 9 (400 mw)
Kindly suggest me for best performance with higher bandwidth card or board for more then 20 Mbps
waiting for your reply …
rgd
Any card, that supports 802.11 g or/and 802.11a allows to achieve 20 Mbps bandwidth.
If you will have reliable communication between AP and client, RB52 card should work fine for such setup (information about R52 card, http://www.mikrotik.com/pdf/R52.pdf ).
hiii
sergis , iam using nmp-8602 with rb-112 maximum bandwidth achive 6 mbps maximum card tx power is 400 Mw , shall i process for r53 card or 532 router borad for more bandiwdth
rgd
