It’s a must when you have multiple devices and you are mandated that all staff shall have their own logins, and you can’t have cleartext passwords laying around. Yes, I know that RADIUS is possible, but RADIUS not always reachable.
Other vendors ( like Cisco, Fortinet, …) will never allow to inject a user/password (hash) combination for an administrator. This would be a way to either alter or reset the admin password or to inject an user with admin rights and known password. Depending on the hashing technique (and “salt” ) the hash may/should be different for the same username/password combination on different devices, or even on the same device at different instances.
If is not possible, let us export full user database (like certificate database, dude database and user-manager database)
forcefully aes-sha256 password protected
like the “backup” but only with user database.
You have ready 98% of code… simply add a flag on backup “export user only”
and add on restore “import user only”…
It is stupid that this is still not a thing
If nothing else, hash is extremely useful for identifying vulnerable passwords. I.e. old/outdated/common passwords on devices that should be changed. This is EASILY checked if the hash exists in the config, very simple regex or any other comparator that scans config files. It is a bloody pain in the ass to do it any other way (having to write scripts that attempt logins, generating tons of error trash in the log file)
Ironically including the hash is actually far more secure for the above reason, also to check if a password has successfully changed via mass push, or was unintentionally altered at some point
The smart method is RADIUS logins for all users, monitoring platforms etc and visible hashes for local users. But monitoring/management platforms are gimped without the ability to show hashes of user accounts. FFS mikrotik pull your finger out and include this
