Request Basic Setup Assistance RB2011UAS-2HnD-IN
Hi there, I hope this message reaches you well, and thanks for your time and assistance in advance.
I just bought a RB2011UAS-2HnD-IN and trying to use it as a router at home, just like the other routers I have bought from retail stores, and setup easily.
The Winbox util connect to router is available via ethernet port 2, but not sure what to change other than SSID and password.
I reset the modem and connect to the router port1, then turn on router.
I can see the wireless and connect, but no internet.
I suspect maybe the default IP address range, and possibly MAC address, as per info I have read, though shouldn’t it work out of the box?
Thanks for your assistance,
Michael
