Request for Dude Client 64bit
Hello Mikrotik Team,
Please do the needful to release the Dude Client 64bit as nowdays 32bit is no longer widely used.
We are using Mac with M Series which is ARM Based. MAC No Longer supports 32bit.
If there is any workaround please suggest.
It would be good and for now we have some workarounds
  1. Dude Client 64 bits
  2. Is too much to ask for Dude x64 windows client?
Hello there,
First post on this forum :slight_smile:
I’m on macbook pro M2 pro running Sonoma. Running The Dude server on my RB5009
Discovered The Dude this morning, and managed to run it with this :
https://github.com/Gcenx/WineskinServer
Very easy and no problem for now, but i’m new to The Dude
@STMX38
Thank you so much for the workaraound.
Now Dude Client is working with my MACBOOK Air M1.
Wine with 32bit support helped.
