I have purchased two Mikrotik SXT SA5 AC radios for a point-to-point (PTP) connection between two locations that are 1 kilometer apart. Although both radios have been upgraded to the latest firmware and all settings have been correctly configured, I am facing issues due to restrictions in the frequency mode and country settings.
In the frequency mode, only the regular domain option is available, and in the country list, the only option is ETSI 5.5-5.7 GHz. This means I am unable to use the superchannel mode, which I need for my location. Additionally, the antenna gain value is locked at 25 dBi, and I cannot set it to the actual antenna gain, which is 14 dBi.
Could you please guide me on how I can enable the no_country_set option in the country list, allowing me to use the correct frequency range and set the antenna gain to its actual value?
Thank you for your assistance.
