request for help with AdGuard setup
Long story short: My MK ran out of memory and my Adguard stopped working. Stupid me tried to restore from backup file and now because of that I lost AG container as well.
Because of this I need to setup new AG. I added usb drive so next time I won’t have memory issue.
I believe I did everything according to the instructions but looks like I’m stack. For whatever reason now I cannot ping 172.17.0.2. Here is my current config:
# 2024-09-14 22:30:29 by RouterOS 7.14.3
# software id =  [REMOVED]
# model = RB5009UG+S+
# serial number =  [REMOVED]
add name=br-Uplink port-cost-mode=short vlan-filtering=yes
add name=containers
set [ find default-name=ether1 ] comment="POE swith /wi-fi" name=\
    ether1-LAN-Hybrid
set [ find default-name=ether2 ] comment=proxmox name=ether2-LAN-Hybrid
set [ find default-name=ether3 ] comment="ABB IPS 2.1" name=ether3-LAN-Access
set [ find default-name=ether4 ] name=ether4-LAN
set [ find default-name=ether7 ] comment=mngmnt name=ether7-LAN-mngmnt
set [ find default-name=ether8 ] name=ether8-WAN-Static
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface veth
add address=172.17.0.2/24 gateway=172.17.0.1 gateway6="" name=veth1
/interface wireguard
add listen-port=14567 mtu=1420 name=wireguard1
/interface vlan
add comment="Management VLAN" interface=br-Uplink name=Management-10 vlan-id=\
    10
add comment="Smart Home VLAN" interface=br-Uplink name="Smart Home-30" \
    vlan-id=30
add comment="Users VLAN" interface=br-Uplink name=Users-100 vlan-id=100
add comment="Servers VLAN" interface=br-Uplink name=vlan20-Servers vlan-id=20
add name=LAN
add name=WAN
add name=MGMT
add name=dhcp_management_pool ranges=192.168.10.242-192.168.10.249
add name=dhcp_users_pool ranges=192.168.100.100-192.168.100.249
add name=dhcp_smarthome_pool ranges=192.168.30.100-192.168.30.249
add name=dhcp_servers_pool ranges=192.168.12.242-192.168.12.254
add address-pool=dhcp_management_pool interface=Management-10 name=\
    dhcp-management
add address-pool=dhcp_users_pool interface=Users-100 name=dhcp-users
add address-pool=dhcp_smarthome_pool interface="Smart Home-30" name=\
    "dhcp-smart home"
add address-pool=dhcp_servers_pool interface=vlan20-Servers name=dhcp-servers
/container
add interface=veth1 logging=yes root-dir=/Adguard start-on-boot=yes workdir=\
    /opt/adguardhome/work
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1-part1
add bridge=br-Uplink comment="unmanaged switch poe" interface=\
    ether1-LAN-Hybrid internal-path-cost=10 path-cost=10 pvid=30
add bridge=br-Uplink comment=proxmox interface=ether2-LAN-Hybrid pvid=20
add bridge=br-Uplink comment="ABB IPS" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether3-LAN-Access pvid=\
    30
add bridge=br-Uplink comment="office(right socket)" frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether4-LAN pvid=10
add bridge=br-Uplink comment=unknown frame-types=\
    admit-only-untagged-and-priority-tagged interface=ether7-LAN-mngmnt pvid=\
    10
add bridge=containers interface=veth1
set udp-timeout=10s
set discover-interface-list=MGMT
/interface bridge vlan
add bridge=br-Uplink tagged=ether2-LAN-Hybrid,br-Uplink untagged=\
    ether1-LAN-Hybrid,ether3-LAN-Access vlan-ids=30
add bridge=br-Uplink comment="wifi users" tagged=\
    ether1-LAN-Hybrid,br-Uplink,ether2-LAN-Hybrid vlan-ids=100
add bridge=br-Uplink tagged=ether1-LAN-Hybrid,br-Uplink,ether2-LAN-Hybrid \
    vlan-ids=10
add bridge=br-Uplink tagged=ether1-LAN-Hybrid,br-Uplink untagged=\
    ether2-LAN-Hybrid vlan-ids=20
add interface=ether8-WAN-Static list=WAN
add interface=Management-10 list=LAN
add disabled=yes interface=br-Uplink list=LAN
add interface=Users-100 list=LAN
add interface=wireguard1 list=LAN
add interface=wireguard1 list=MGMT
add interface=Management-10 list=MGMT
add interface="Smart Home-30" list=LAN
add interface=vlan20-Servers list=LAN
/interface wireguard peers
add allowed-address=10.10.20.2/32 comment= [REMOVED] interface=wireguard1 \
    public-key= [REMOVED]
add allowed-address=10.10.20.3/32 client-dns=172.17.0.2 comment=\
     [REMOVED] interface=wireguard1 public-key=[REMOVED]
add allowed-address=10.10.20.4/32 client-dns=172.17.0.2 interface=wireguard1 \
add address= [REMOVED] interface=ether8-WAN-Static network= [REMOVED]
add address=192.168.12.1/24 interface=vlan20-Servers network=192.168.12.0
add address=192.168.100.1/24 interface=Users-100 network=192.168.100.0
add address=192.168.10.1/24 interface=Management-10 network=192.168.10.0
add address=192.168.30.1/24 interface="Smart Home-30" network=192.168.30.0
add address=10.10.20.1/24 interface=wireguard1 network=10.10.20.0
add address=172.17.0.1/24 interface=containers network=172.17.0.0
/ip dhcp-server lease
add address=192.168.10.250 client-id= [REMOVED] comment=\
     [REMOVED] mac-address= [REMOVED] server=dhcp-management
add address=192.168.10.6 client-id= [REMOVED] comment=\
    "TP Link EAP 615 Bedroom" mac-address= [REMOVED] server=\
    dhcp-management
add address=192.168.10.5 client-id= [REMOVED] comment=\
    "TP Link EAP 615 Living Room" mac-address= [REMOVED] server=\
    dhcp-management
add address=192.168.100.204 client-id=1:48:a6:b8:7:73:e2 comment="Sonos ARC" \
    mac-address=48:A6:B8:07:73:E2 server=dhcp-users
add address=192.168.100.249 client-id=1:72:70:2a:fe:13:ab comment=\
    "iPad Living Room" mac-address=72:70:2A:FE:13:AB server=dhcp-users
add address=192.168.100.203 client-id=1:54:2a:1b:23:ee:38 comment="Sonos SUB" \
    mac-address=54:2A:1B:23:EE:38 server=dhcp-users
add address=192.168.100.202 client-id=1:f0:f6:c1:c5:cf:d4 comment=\
    "Sonos ERA 300" mac-address=F0:F6:C1:C5:CF:D4 server=dhcp-users
add address=192.168.100.201 client-id=1:f0:f6:c1:c5:cf:58 comment=\
    "Sonos ERA 300" mac-address=F0:F6:C1:C5:CF:58 server=dhcp-users
add address=192.168.30.2 client-id=1:2:78:7f:7f:66:2e comment=\
    "Home Assistant" mac-address=02:78:7F:7F:66:2E server="dhcp-smart home"
add address=192.168.30.205 client-id=1:64:d2:c4:e1:f5:dc comment=\
    "Apple TV Bedroom - Wireless" mac-address=64:D2:C4:E1:F5:DC server=\
    "dhcp-smart home"
add address=192.168.30.3 comment="ABB IPS2.1 (KNX)" mac-address=\
    00:0C:DE:93:50:5A server="dhcp-smart home"
add address=192.168.30.250 client-id=1:b0:a4:60:9a:8c:1a comment=\
    "YOGA camelot" mac-address=B0:A4:60:9A:8C:1A server="dhcp-smart home"
add address=192.168.100.250 client-id=1:b0:a4:60:9a:8c:1a comment=\
    "YOGA castle" mac-address=B0:A4:60:9A:8C:1A server=dhcp-users
add address=192.168.30.4 client-id=1:0:24:6d:2:a6:6c comment=1HOME \
    mac-address=00:24:6D:02:A6:6C server="dhcp-smart home"
add address=192.168.30.5 client-id=1:64:d2:c4:d4:fb:c7 comment=\
    "Apple TV Bedroom - Wired" mac-address=64:D2:C4:D4:FB:C7 server=\
    "dhcp-smart home"
add address=192.168.12.244 client-id=1:3c:2a:f4:4c:81:e8 comment=\
    "Brother HL-3170CDW Printer" mac-address=3C:2A:F4:4C:81:E8 server=\
    dhcp-servers
add address=192.168.30.251 client-id=1:e2:2e:15:51:59:4e comment=\
    "Lubo Ipad Pro" mac-address=E2:2E:15:51:59:4E server="dhcp-smart home"
add address=192.168.100.251 client-id=1:9a:62:bd:95:32:39 comment=\
    "Lubo IPhone 15 Pro" mac-address=9A:62:BD:95:32:39 server=dhcp-users
add address=192.168.30.252 client-id=1:36:aa:c:fc:82:7d comment=\
    "Lubo IPhone 15 Pro" mac-address=36:AA:0C:FC:82:7D server=\
    "dhcp-smart home"
add address=192.168.10.0/24 comment=mngmt dns-server=172.17.0.2,8.8.8.8 \
    gateway=192.168.10.1
add address=192.168.12.0/24 comment=servers dns-server=172.17.0.2,8.8.8.8 \
    gateway=192.168.12.1
add address=192.168.30.0/24 comment="smart home" dns-server=\
    172.17.0.2,8.8.8.8 gateway=192.168.30.1
add address=192.168.100.0/24 comment=users dns-server=172.17.0.2,8.8.8.8 \
    gateway=192.168.100.1
set allow-remote-requests=yes servers=172.17.0.2,8.8.8.8
/ip firewall address-list
add address=192.168.12.0/24 list=Servers
add address=192.168.100.0/24 list=Users
add address=192.168.30.0/24 list=SmartHome
add address=192.168.12.0/24 list=LAN
add address=192.168.30.0/24 list=LAN
add address=192.168.10.0/24 list=LAN
add address=192.168.100.0/24 list=LAN
add address=88.203.229.253 list=Svetulcho
add address=192.168.10.250 comment="admin local" list=Authorized
add address=192.168.30.250 comment="admin wifi" disabled=yes list=Authorized
add address=10.10.20.2 comment="admin remote wireguard" list=Authorized
add address=10.10.20.3 comment="admin remote ios wireguard" list=Authorized
add address=192.168.100.251 comment="admin wifi" disabled=yes list=Authorized
add address=10.10.20.4 comment="admin remote ios wireguard" list=Authorized
add address=10.10.20.0/24 list=LAN
    established,related,untracked
    connection-state=invalid
add action=accept chain=forward comment="allow internet traffic" \
    in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow access from LAN to Plex" \
    dst-address=192.168.12.140 dst-port=32400 protocol=tcp src-address-list=\
    LAN
    "allow access from LAN to Home Assistant" dst-address=192.168.30.2 \
    dst-port=8123 protocol=tcp src-address-list=LAN
add action=accept chain=forward comment="LAN to Adguard" dst-address=\
    172.17.0.2 src-address-list=LAN
add action=accept chain=forward in-interface-list=MGMT out-interface-list=LAN \
    src-address-list=Authorized
add action=accept chain=forward comment="port forwarding" \
    connection-nat-state=dstnat
    "allow access for containers to internet" in-interface=containers \
    out-interface=ether8-WAN-Static
add action=drop chain=forward comment="Drop all else"
    "accept established, related, untracked" connection-state=\
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment="wireguard handshake" dst-port=14567 \
    protocol=udp
add action=accept chain=input comment="Access for MGMT" in-interface-list=\
    MGMT src-address-list=Authorized
add action=accept chain=input comment="users to services" dst-port=53 \
    in-interface-list=LAN protocol=udp
    in-interface-list=LAN protocol=tcp
add action=drop chain=input comment="Drop all else"
add action=masquerade chain=srcnat out-interface=ether8-WAN-Static
add action=dst-nat chain=dstnat comment="port 443 to nginx proxy" dst-port=\
    443 in-interface=ether8-WAN-Static protocol=tcp to-addresses=\
    192.168.12.254 to-ports=443
add action=dst-nat chain=dstnat comment="port 32400 to Plex" dst-port=32400 \
    in-interface=ether8-WAN-Static protocol=tcp to-addresses=192.168.12.140 \
    to-ports=32400
add disabled=no dst-address=0.0.0.0/0 gateway= [REMOVED] routing-table=main \
    suppress-hw-offload=no
/system clock
set time-zone-name= [REMOVED]
/system identity
set name=RB5009
/system note
set show-at-login=no
/tool mac-server mac-winbox
set allowed-interface-list=MGMT
/tool sniffer
set filter-interface=ether2-LAN-Hybrid
