I hope this email finds you well. We are currently exploring ways to automate the process of changing L2TP passwords in our MikroTik routers to enhance our network security measures.
To achieve this automation, we are seeking a Python script that can interact with the MikroTik RouterOS API to change the L2TP password programmatically. We understand that the RouterOS API provides functionality for managing router configurations remotely, and we believe that a Python script leveraging this API can help us achieve our goal efficiently.
Ideally, the Python script should:
Connect to the MikroTik router using the RouterOS API.
Authenticate with the router using appropriate credentials.
Execute commands to change the L2TP password securely.
We would greatly appreciate it if you could provide us with a sample Python script or code snippet that demonstrates how to accomplish this task using the MikroTik RouterOS API.
Additionally, any documentation or resources related to the RouterOS API that could assist us in understanding its capabilities and usage would be highly beneficial.
Thank you very much for your assistance in this matter. We look forward to hearing from you soon.
For background, Mikrotik has several “APIs”. The low-level one is what typically called “API”, and there is a python module wrappers: https://help.mikrotik.com/docs/display/ROS/API#API-Exampleclient
This is more useful is were building a UI or for a “long poll” to continuously fetch data from RouterOS. But it’s a lot of plumbing code to setup just for something like a password change.
So @mada3k is right using “REST API”, which uses normally HTTP(S) on port 80/443, is likely easier for something like changing password: https://help.mikrotik.com/docs/display/ROS/REST+API
The REST API mimic the CLI, and Python libraries like “requests” (or similar python HTTP client module) can call it like any other web service.
Often it’s easier to start with the RouterOS CLI that you know it does what you want FIRST. Then… use the CLI command as the guide what the specific REST API call should be – since it largely putting the CLI parameters into JSON for change into body with the URL being /rest + CLI command.
For ROS API (not REST) you have Python3 example on MT help page or use pip packages like this or this.
For REST API, it should work with any HTTP client (like requests module mentioned above), requests and responses bodies are in JSON format. For eg. here is some Python module which is using REST API with requests module using JSON<->Python object (de)serialization.
