I have a satellite connection as well as adsl line, I would like to have traffic shapeing setup, but wiki does not have an example for dynamic ip assigned by ADSL.
The router is setup as transparent bridge, as MT box does not seem to communicate properly when setup as router.
So we have pppoe connection running from MT router through ADSL modem to ISP and a static ip on satellite router.
If I had two static gateways, the wiki example would be simple.
But I have tried and ended up having to setup MT router again, as when clients connect they get nothing.
Your router is a transparent bridge, what IP is being assigned to the MT Ethernet(WAN) port? a private IP or the internet public IP?
do you have a static route 0.0.0.0/0 to the gateway IP? do you have a srcnat masquerade (NAT)?
If PPPoE to your ISP from MT is easy, through winbox, checkboxes “create default route” and “use peer dns” on the PPPoE client interface. then have srcnat masquerade to that PPPoE client interface in MT.
The Wan PPPOE IP is dynamically assigned by ISP, and is a public address.
Yes, there is a static route, and when I click the checkbox for add default route on PPPOE connection, then internet no longer works.
Yes, we do have NAT–>SRC–>Masquarade
I have successfully connected to PPPOE connection through mikrotik, but as soon as we connect even when using “add default route” on PPPOE connection the internet is no longer accessable, then we have to disconnect PPPOE make sure the routes are pointing back to the Satellite link for the internet to come back online.
and your DNS inside MT needs to be enabled for “allow remote requests”
If these are met and you check the add default route, add dns on the PPPoE then all data that is not matched on your LAN will be routed through the PPPoE interface, you shouldn’t need a static route.
