Request: IP-SLA
http://www.cisco.com/c/en/us/products/ios-nx-os-software/ios-ip-service-level-agreements-slas/index.html
I would like to see something similar to Cisco’s IP-SLA. Something to monitor the jitter latency, throughput, etc. in real time for enforcing or proving SLAs.
Sent from my EVO using Tapatalk
Would love to use these as probes as well as pull stats off of existing routers.
Ccm messaging as part of g.8032 ethernet rings can be used this way. Kill 2 birds with one stone.
+1 !
Netwatch can do some of this but it would be nice to have a protocol baked into ROS that can handle this
That would be nice.
Yes, I also need this for latency/jitter/packet loss detection
I would love to see this feature.
We maintain some fairly large WAN’s and this would be a huge benefit to us.
I want IP-SLA Please…
Please… It would be nice to be able to make adjustments to how much of the router’s resources can be dedicated to IP-SLA Tasking.
I wrote a script for monitoring latency and packet loss. If anyone else would like to use it, let me know and I’ll post it.
I’m interested.
I’m interested too.
I know that this is not for this topic but I am interested. How much money is SLA in your countries? Could You give me some prices ?
OK, here it is.
The below script is a “setup” to create all the items necessary to setup a monitor on one IP address. By its self, this setup does nothing but monitor one ip address and based on the results, sets a global variable for to “up” or “down”. You need another “failover” script to monitor these global variables and take action. I’ll post my failover script shortly.
Here is what the setup script does though:
  1. Creates a “probe” script & schedule that runs a ping and stores the latency
  • Set “probeInterval” to decide how frequently scheduler runs this
  • Set “livesKept” to decide how many ping results to store (I recommend keeping 100)
  • Set “target” to the IP you want to monitor
  • Set “ipslaName” to the name. Should be “ipsla1”, “ipsla2”, etc.. Each must be unique.
  1. Creates a “analyze” script & schedule that runs analysis on the stored ping responses
  • Set “analyzeInterval” to decide how frequently scheduler runs this
  • Set “checkNumStats” to decide how many previous statistics to calculate loss on. I set this to the same value as “livesKept” since I don’t care about storing data longer than it is used to calculate the average latency/average packet loss
  • Set “latencyThreshold” to the average milliseconds threshold for the monitor to go to a “down” state
  • Set “lossThreshold” to the percent packet loss threshold for the monitor to go to a “down” state
  1. Creates rules in /ip proxy access . These rules do nothing but store ping values for each instance
  • If you use “/ip proxy” for it’s intended purpose (running a proxy), you will have to find a different area to store the ping variables in and adjust this script.
Before running the setup, please edit values under the, “User set Variables” comment first. This was tested on ROS version 5.26.
#Script creates variable storage in /ip proxy access for an ipsla instance.
# User set Variables
#Variable represents the name of the ipsla instance (recommended to name them: ipsla1, ipsla2...ipslaN)
:local ipslaName ipsla1;
#IP to ping
:local target "4.2.2.2";
#Size of pings to send
:local size "1200";
#Variable represents total number of ping records to keep
:local livesKept 100;
:local probeInterval "10s";
#Analyze Interval should be a multiple of the probe interval
:local analyzeInterval "4m";
#Number of previous statistics to calculate loss/latency averages on
:local checkNumStats 100;
#Threshold for when latency will cause monitor to be down status
:local latencyThreshold 500;
#Threshold for when packet loss will cause monitor to be down status (this_variable is a percentage)
:local lossThreshold 15;
#Add proxy rules for storing ping statistics
#Add record with comment stating rules
/ip proxy access add action=allow comment="9999 - Flag for ping timed out.     For \"Current Index\" record: dst-port is current index, dst-host is total number of records           For standard records:  dst-port column is latency, dst-host column is number"
:for i from=0 to=$livesKept do=\
    :if (i=0) do={ /ip proxy access add action=allow disabled=no dst-port=1 dst-host="$livesKept" comment="Current Index - $ipslaName";}\
    else=\
        /ip proxy access \
        add action=allow disabled=no dst-port=0 dst-host="$i" method=$ipslaName;
#Add scheduling for probe and analyze scripts
/system scheduler
add comment="Run every X seconds" disabled=no interval=$probeInterval name=\
    ($ipslaName."_probe") on-event=($ipslaName."_probe") policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
    start-time=startup
add comment="Should run on an interval that is a multiple of $ipslaName _probe interv\
    al (Recommended to multiply by the \"checkNumStats\" variable in the analyze\
    \_script)" disabled=no interval=$analyzeInterval name=($ipslaName."_analyze") \
    on-event=($ipslaName."_analyze") policy=\
    start-time=startup
#Add probe script
/system script
add name=($ipslaName."_probe") policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api source="# Variables - $ipslaName\
    \n:global $ipslaName;\
    \n:local name $ipslaName;\
    \n:local response  -1;\
    \n:local target $target;\
    \n:local pingSize $size;\
    \n\
    \n#Variables derived from stored settings\
    \n:global floodpingisbusy;\
    \n:local currentIndex;\
    \n:local livesKept;\
    \n:local currentStat;\
    \n\
    \n#Check if floodping is being used and delay if so\r\
    \n:while (\$floodpingisbusy) do={ /delay delay-time=1 };\r\
    \n\r\
    \n#Mark floodping as used before using\r\
    \n:set floodpingisbusy value=true;\r\
    \n#Ping target and gather latest statistic\r\
    \n/tool flood-ping \$target count=1 size=\$pingSize do=\\\r\
    \n{\r\
    \n    :set response \$\"avg-rtt\";\r\
    \n};\r\
    \n#reset floodpingisbusy so other processes can use it again\r\
    \n:set floodpingisbusy value=false;\r\
    \n\r\
    \n#Get stored Index\r\
    \n:set currentIndex [/ip proxy access get [find comment=\"Current Index - \$name\"] dst-port]; \
    \n:set currentStat [/ip proxy access find (method=\"\$name\" and dst-host=\"\$currentIndex\")];\
    \n:set livesKept [/ip proxy access get [find comment=\"Current Index - \$name\"] dst-host]; \
    \n\
    \n#Check if no response\
    \n:if (\$response = 0) do=\\\
    \n{\
    \n    /ip proxy access set \$currentStat dst-port=9999 dst-address=\$target;\
    \n} \\\
    \nelse=\\\
    \n{\
    \n    /ip proxy access set \$currentStat dst-port=\$response dst-address=\$target;\
    \n};\
    \n\
    \n#Increment index to next (set back to start if at end)\
    \n:if (\$currentIndex>=\$livesKept) do=\\\
    \n{\
    \n    :set currentIndex 1;\
    \n} else=\\\
    \n{\
    \n    :set currentIndex (\$currentIndex+1);\
    \n};\
    \n\
    \n/ip proxy access set [/ip proxy access find comment=\"Current Index - \$name\"] dst-port=\$currentIndex"
#Add analyze script
/system script
add name=($ipslaName."_analyze") policy=\
   source=("\
   \n#User set variables\
   \n#Variable for storing up/down status of ipsla (if this variable is edited, make sure to edit checks at the end of this script)\
   \n:global $ipslaName\
   \n## Global variable for viewing current packet loss\
   \n:global ".$ipslaName."PacketLossPercent\
   \n##Global variable for viewing current average latency\
   \n:global ".$ipslaName."AverageLatency\
   \n##Name (must match the name used in createStorageVariables script\
   \n:local ipslaName $ipslaName;\
   \n#Number of previous statistics to calculate loss/latency averages on\
   \n:local checkNumStats $checkNumStats;\
   \n#Threshold for when latency will cause monitor to be down status\
   \n:local latencyThreshold $latencyThreshold;\
   \n#Threshold for when packet loss will cause monitor to be down status (this\
   \_variable is a percentage)\
   \n:local lossThreshold $lossThreshold;\
   \n\
   \n:local livesKept [/ip proxy access get [find comment=\"Current Index - \$i\
   pslaName\"] dst-host]; \
   \n:local currentStatLatency;\
   \n:local currentIndex [/ip proxy access get [find comment=\"Current Index - \
   \$ipslaName\"] dst-port];\
   \n#Decrease current index by one since current index is pending update but c\
   urrentindex-1 is the most recently updated\
   \n:if (\$currentIndex=1) do=\\\
   \n{ \
   \n    :set currentIndex (\$livesKept); \
   \n} else=\\\
   \n{ \
   \n    :set currentIndex (\$currentIndex-1); \
   \n};\
   \n:local startIndex \$currentIndex;\
   \n:local totalLatency 0;\
   \n:local avgLatency;\
   \n:local percentLoss;\
   \n:local received 0;\
   \n:local lost 0;\
   \n:local polledIp;\
   \n\
   \n#Go through loop as many times as necessary to gather each statistic that \
   will be calucalted upon\
   \n:for i from=1 to=(\$checkNumStats) do=\\\
   \n{\
   \n#### Store latency of current statistic\
   \n    :set currentStatLatency [/ip proxy access get [find (method=\"\$ipslaN\
   ame\" and dst-host=\"\$currentIndex\")] dst-port]; \
   \n#### Check if value is flagged with 9999 (ping timed out)\
   \n    :if (\$currentStatLatency=9999) do={:set lost (\$lost+1);} else=\\\
   \n    {\
   \n######## If not timed out, add latency to total\
   \n#        :put \$currentStatLatency\
   \n        :set received (\$received+1);\
   \n        :set totalLatency (\$totalLatency+\$currentStatLatency);\
   \n    };\
   \n####Check if index is at the end of the statistic list, reset to beginning\
   \_if necessary\
   \n    :if (\$currentIndex=1) do=\\\
   \n    { \
   \n    } else=\\\
   \n    { \
   \n    };\
   \n};\
   \n:set polledIp [/ip proxy access get [find (method=\"\$ipslaName\" and dst-\
   host=\"\$currentIndex\")] dst-address];\
   \n:set percentLoss ((\$lost*100) / ((\$received+\$lost)));\
   \n:if (\$received=0) do=\\\
   \n{\
   \n    :set avgLatency 0;\
   \n} else=\\\
   \n{\
   \n    :set avgLatency (\$totalLatency/\$received);\
   \n};\
   \n\
   \n#Log statistics\
   \n:log info \"Ran \$ipslaName analyze script, checked last \$checkNumStats p\
   oll(s) on \$polledIp\"\
   \n:log info \"Average Latency: \$avgLatency\";\
   \n:log info \"Percent loss: \$percentLoss (lost: \$lost, Received \$received\
   \n\
   \n#Add whatever checks on latency and percent loss down here along with acti\
   ons\
   \n:if ((\$percentLoss>\$lossThreshold) || (\$avgLatency>\$latencyThreshold))\
   \_do=\\\
   \n{\
   \n    :if (("."\$"."$ipslaName)!=\"down\") do=\\\
   \n    {\
   \n        :set $ipslaName \"down\"\
   \n        :log error (\"\$ipslaName is down\"); \
   \n        :log error (\"Packet Loss: \$percentLoss  Average Latency: \$avgLa\
   tency\");\
   \n    };\
   \n} else=\\\
   \n{\
   \n    :if (("."\$"."$ipslaName)=\"down\") do=\\\
   \n    {\
   \n        :log error (\"\$ipslaName is back up\");\
   \n    };\
   \n    :set $ipslaName \"up\";\
   \n    :set ".$ipslaName."PacketLossPercent \$percentLoss;\
   \n    :set ".$ipslaName."AverageLatency \$avgLatency;\
   \n };")
Keep in mind that this script uses floodping since regular ping can not return a latency value to a script. Floodping can only run one instance at a time so these scripts use a global variable called, “floodpingisbusy” to check whether it is in use by another probe monitor before trying to probe. For this reason, I don’t think you can run many more than 4 or 5 probe scripts at a time (depending on the probe interval, this 4-5 estimate is based on 10s interval).
Some useful suggestions after running initial setup:
  1. Go to IP → Proxy → Access and see current values to confirm this is working
  2. Go to System → Scripts → Environment to see current values of global variables
  3. Watch logs to see “analyze” scripts running and current statistics
Please feel free to post suggestions or improvements.
I believe IP-SLA goes in hand with, yet different from Y.1731. I want that too. :wink:
http://forum.mikrotik.com/t/request-y-1731-performance-monitoring/83838/1
+1 on this
bump
Yup, +1
That said, I still rank most of the IPv6 feature requests above this one in respect to dev time.
+1 IP-SLA
bump
