hello,
are there any plans for a RB2011 with MiniPCI-e slot support ?
it would be great if you could add a LTE interface into these boxes.
usb stick isn´t really sexy in a cabinet or at a business customer.
best
florian
hello,
best
florian
+1
Enviado desde mi LG-D855
at least an internal cloned USB connector, so we can put LTE stuff (or simply Usk key for storage) without having it flying around ![]()
I’m not exactly sure how you would get it inside, but conceivably, since the USB connector is Micro-USB, you could take the full-size USB end of the adapter that MikroTik ships with the 2011 and put it (and your USB stick) on the inside of the case somewhere. You would have a short piece of wire looping from inside the case to the Micro-USB connector, but at least the stick wouldn’t be flopping around outside.
– Nathan
