[Request] VRRP track interface or address
With Cisco HSRP, you can make fail-over track the state of another interface. For instance, you can make a LAN interface fail-over if an upstream interface is down.
It would be great if MikroTik could add such capability to the VRRP configuration, so that VRRP fail-over can be forced if either another interface fails or a next hop (or possibly other IP address) is not reachable.
This is possible with scripting.
can you post the working script for this ?
thx
