Hello. I have mail server running with real domain like mail.mydomain.com. Lets say my static ip is “xx.xx.xx.xx” and mail server local ip address is “yy.yy.yy.yy”. What i want to do is redirect requests sent from local network to mail.mydomain.com so “xx.xx.xx.xx” should be redirected to “yy.yy.yy.yy”. Someone suggested me that i could use loopback feature but i’m don’t used it before and not sure how to do that. Can some show me some examples or lead me if is there a better way to do it? Thanks already.
Here’s basic info:
https://wiki.mikrotik.com/wiki/Hairpin_NAT
And some extra hints:
http://forum.mikrotik.com/t/hairpin-nat-is-there-a-simple-solution/140385/19
Finally, after long time i did it thanks to you ![]()
Sorry for stealing your topic but:
I have similar problem:
Web server located on local network. Server uses port 444.
NAT port forwarding all incoming from 443 to 444 enabled.
When I connect to cloud.myserver.lv from outside, everything works.
When I connect to cloud.myserver.lv from local network, browser shows this error
The connection for this site is not secure
cloud.myserver.lv uses an unsupported protocol
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Tried to add
ip firewall nat add action=dst-nat chain=dstnat dst-address=publicIP dst-port=443 protocol=tcp to-addresses=192.168.88.248
ip firewall nat add action=masquerade chain=srcnat dst-address=192.168.88.248 dst-port=443 out-interface=bridge protocol=tcp src-address=192.168.88.0/24
Now the browser shows this:
This site can’t be reachedcloud.myserver.lv refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
What I’m missing?
Tried to add
ip firewall nat add action=dst-nat chain=dstnat dst-address=publicIP dst-port=443 protocol=tcp to-addresses=192.168.88.248 ???
TO
ip firewall nat add action=dst-nat chain=dstnat dst-address=publicIP dst-port=443 protocol=tcp to-addresses=192.168.88.248 to-ports=444
ip firewall nat add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=192.168.88.0/24
Alternatively simply move your server to a different subnet and the extra hairpin nat src rule is not required
Thanks, that helped!
About moving server to different network. Will my file server work then? Can i still mount drives to my PC without additional nat rules?
Not sure what you mean if your file server will work? what subnet a file server is on has no bearing on the functionality of the file server itself?
Not sure what you mean about mounting drives??
yes, but your PC’s must accept route redirects.
