Require microtik hotspot login templet
please send me microtik login templet
my id is sumitisavailable@gmail.com
i will thankfull for you
You mean the login.html from the mikrotik hotspot page?
Open Winbox, then click Files. You’ll see a folder there named hotspot which contain all template files. Just drag the whole hotspot folder to your dekstop and everything will be copied.
