Hi Team,
Do we have any transmitter & Receiver product line for the drone communication in 2.4 ghz.
Thanks & Rgds
Sampathkumar
Hi Team,
Thanks & Rgds
Sampathkumar
Check product line: https://mikrotik.com/products
Think that any of that devices are not suitable to be mounted into drone.
Thanks for the prompt reply.
If in case, if I choose RB912UAG-2HPnD. is it possible to select the communication channel via usb instead of ethernet for the data transfer.
No, except supported usb serial ports.
You can not do anything for extend “standard” drone remote control.
