I would like to my upstream provider to resend prefixes to me, they give me their juniper command for reference:
clear ip bgp <neighbor_ip> soft in
please what is the command can do this in MikroTik?
I am using CCR1036 Ver 6.7
Many thanks!
Many thanks!
It is not Juniper command, it is Cisco command… ![]()
And this should help you: http://wiki.mikrotik.com/wiki/Manual:BGP_soft_reconfiguration_alternatives_in_RouterOS
/routing bgp peer refresh
It is not 100% same, but result should be pretty much that you want to achieve.
Thanks for your soon reply.
Then, can I find prefix by a ip address?
For example:
I just know 121.21.100.207 is unreachable, but I don’t know what is it’s prefix.
I need to confirm received this prefix after peer refresh, how do I do?
Many thanks!
/ip route print where dst-address = <prefix>
or
/ip route print where dst-address in <prefix range>
Many thanks!!
I found the syntax:
/ip route print where x.x.x.x in dst-address
