Is there any way to reset the configuration on a RB1000 before boot? One of mine has a bad config and as soon as it boots it crashes. Or is it possible to reload RouterOS on the built in flash?
Please see below:
RouterBOOT booter 2.12
RouterBoard 1000
CPU frequency: 1333 MHz
Memory size: 512 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
Starting services…
MikroTik 3.3
MikroTik Login:
RouterBoard 1000
Memory size: 512 MB
Starting…
Starting services…
MikroTik 3.17
MikroTik Login: ------------[ cut here ]------------
Oops: Exception in kernel mode, sig: 5 [#1]
RB1000
NIP: a10cb860 LR: a19471b4 CTR: a1947130
REGS: 9f019950 TRAP: 0700 Tainted: P (2.6.26.7)
MSR: 00029000 <EE,ME> CR: 44000084 XER: 00000000
TASK = 9fb7e8a0[832] ‘discover’ THREAD: 9f018000
GPR00: 00000001 9f019a00 9fb7e8a0 9f2650f8 9f019ab8 00000004 00000004 00000000
GPR08: 00000001 9e8da300 00000000 9e8d4240 c0a823c7 10025100 802186c4 802186e4
GPR16: 00000000 9f019ae8 a192a3e0 00000004 9f04c000 00000000 00000000 00000100
GPR24: 00000001 9f04c000 00000004 a196f000 a196fd18 9f019ab8 9f2650f8 a196fba0
NIP [a10cb860] nf_nat_setup_info+0x78/0x62c [nf_nat]
LR [a19471b4] 0xa19471b4
Call Trace:
[9f019a00] [9f019a38] 0x9f019a38 (unreliable)
[9f019ab0] [a19471b4] 0xa19471b4
[9f019ae0] [a1928a5c] ipt_do_table+0x2f8/0x350 [ip_tables]
[9f019b40] [a194b360] nf_nat_rule_find+0x24/0x540 [iptable_nat]
[9f019b50] [a194b538] nf_nat_rule_find+0x1fc/0x540 [iptable_nat]
[9f019b80] [a194b7dc] nf_nat_rule_find+0x4a0/0x540 [iptable_nat]
[9f019b90] [8017e3f4] nf_iterate+0x68/0xc4
[9f019bc0] [8017e4c0] nf_hook_slow+0x70/0xf4
[9f019c00] [801898b8] ip_mc_output+0x168/0x1f4
[9f019c20] [801886f0] ip_local_out+0x34/0x48
[9f019c30] [80188a08] ip_push_pending_frames+0x304/0x380
[9f019c50] [801a4b3c] udp_push_pending_frames+0x29c/0x2f4
[9f019c80] [801a5d30] udp_sendmsg+0x410/0x518
[9f019d20] [801ac48c] inet_sendmsg+0x60/0x74
[9f019d40] [8015a4c0] sock_sendmsg+0xac/0xd0
[9f019e30] [8015a7f0] sys_sendto+0xbc/0xec
[9f019f00] [8015b0e8] sys_socketcall+0x14c/0x1e8
[9f019f40] [8000c1d0] ret_from_syscall+0x0/0x3c
Instruction dump:
38800001 38a00020 4800fab1 2f830000 419e05bc 2f9a0000 409e0010 801e0064
5400cffe 4800000c 801e0064 5400c7fe <0f000000> 38610008 389e003c 4800a485
Kernel panic - not syncing: Fatal exception in interrupt
panicSaver: dumping panic to flash
flash: erase 10
flash: prg 10
flash: prg err 0
Rebooting in 1 seconds..
