Can we reset device without change any wireless settings?
(with the command “system reset-configuration”).
If it is not possible now, are there any chances to see it in the future?
Thanks.
Thanks.
Yes, it is not possible.
There are two resets,
/system reset-configuration,
which resets entire router configuration;
/interface wireless reset-configuration
reset wireless interface configuration.
So a selective system reset-configuration is what you are asking for.
Something like ‘system reset-configuration ! wireless’ which would reset everything except for the wireless branch of commands.
Or ‘system reset-configuration ! wireless && ip’ which would reset everything except for the wireless and ip.
That could be useful.
Tom
I thought MT had implemented a way to run a script after a system-reset? That way you could reset the entire system, and then have the script configure some settings for you.
